HP iPAQ H1945 Pocket PC Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i get on the internet without using a modem card?
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Jan 14, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833434
Points
6040
Your PDA doesn't have a inbuilt modem or wifi, so you can't use the Internet without a modem card.
Here are the specifications of your iPAQ:
http://reviews.cnet.com/pdas/hp-ipaq-pocket-pc/4507-3127_7-30422067.html
I can not figure out how to connect my device to the internet Wi-Fi, I want to go on internet explorer and it won't connect
To send and receive e-mail with Inbox and view Web sites with Pocket Internet Explorer, set up a remote connection using a modem card or an Ethernet/LAN card.
To connect to the Internet with a modem card, you need a phone line, a dial-up Internet Service Provider, and an optional Single-slot or Dual-slot PC Card Expansion Pack or CompactFlash (CF) Card Expansion Pack.
*Insert your modem card
*From the Start menu, tap Settings
*Tap the Connections tab->Connections Icon-->Internet Settings-->Modify-->New
*Enter a name for the connection, select the modem type, and select the correct baud rate for that modem.
I have shared the basic steps..which I refereed using the reference guide for the model that you have specified from this website.This you can easily get my typing "reference guide for Compaq iPAQ H3850 Pocket PC" in Google...and the first link lets you download the PDF..Follow the steps carefully and connect to the internet.To check for the internet speed you can use Scanmyspeed.com which gives you accurate speed results.
My modem can not detect my lan card, i am using presario v3000, what maybe problem?
Greetings - I think you're not clear about how using the Internet works (not many people are - especially starting out).
The modem and the LAN card are TWO DIFFERENT ways of connecting to the Internet. The modem uses a regular phone line and the LAN card uses Ethernet (a different faster way of connecting to the Internet in which needs further hardware such as a cable or DSL modem from your ISP).
Or is it possible you're talking about connecting your LAN card to your cable or DSL modem?
If this is confusing to you please call the tech support of your Internet service provider and they should be able to walk you through getting connected..
Good Luck and Thanks for using Fix Ya.
Mikeywaf
I use a remote access card on my other laptop -
You can connect to the Internet using a LAN cable.
OR
Copy the the remote access card drivers onto an USB memory stick and the install it on the Aspire One so you can use the remote card.
3helpful
2answers
How can I use Etisalat internet SIM card without the USD modem
No way except you subscribe through Etisalat.
Are u located in Nigeria?
2answers
Share a PPPoE connection without modem
I think the problem is that the modem is not giving enough ip addresses. Try configuring it. Some modems are also a router. This means that it has the capability to provide more ip address so that i can connect more pc.
Connecting my desktop to the internet
the router will NOT provide an internet connection without the use of the modem. just plugging the pc into the back of the router, without a modem in place, will not work.
my best guess, as to why the laptop works is that you may have a broadband connect card.
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
1helpful
WIRELESS MODEM
Pcg U1 doesnt have wireless card. But is has PC card slot. You can buy a PCMCIA wireless card or USB wireless to get access to wireless internet access or PCMCIA modem if you use a modem to access the internet.
I hope this help
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Internet connection
There are 3 ways to connect to the internet. Using a modem with a phone line, an ethernet cable that is hooked up to a high speed internet connection or using wireless. If the laptop does not have a modem, it may have wireless or an ethernet port. Ethernet is slightly larger than a phone jack. If there is wireless there should be a button to turn it on and off somewhere along the top of the laptop where the keyboard is. You could also put get type of those connections on a PCMCIA card which fits into the credit card like slots on the side.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
