Kyocera Mita KM-2530 Laser Printer Logo
Posted on Jan 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kyocera mita KM 2530 wont print. Info gets to printer and blank pages come out. If it 1 page or 10 pages the right quantity of blank pages comes out. Fax prints fine and copiess are fine just no toner on paper for network printing. Have DL'd the most current drivers and no help there
Anonymous
Level 2:
  • Expert 200 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Answers
200
Questions
0
Helped
188739
Points
372
Call kyocera's free help desk Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
Km3035 black print problem in main board
Total equipment cleaning and replace the main charge wire
2helpful
Copier printing solid black kyocera 2530
replace the main charger the problem will be solved
2helpful
Kyocera Mite KM-1510 printing on half pages instead of full pages
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
2helpful
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
2helpful
Copies are printing out a completely black page
Your charge corona grid is shorting out. It either has alot of toner built up on it, (from not cleaning when you change the toner cartridge), or the blocks are bad. You could also have a bad drum ground where the drum makes contact with the machine frame. Only once have I seen a bad drum cleaning blade.
1helpful
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
