Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
