Question about Valor Toys
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
    New Friend:
  • 4 Answers
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Posted on Feb 18, 2011
6ya staff
SOURCE:
How do we start the Oven?
first question
have you turned the gas supply on?
Feb 02, 2018 | Kitchen Ranges
8" yellow flame shooting out of ignition tube when running. No adjustments that I can see on the (Honeywell) gas cut off/pilot valve.
yellow flame is an indication of incorrect air mixture
as it is gas I would suggest that you seek the services of an accredited gas specialists to do any adjustments or repairs
Nov 06, 2015 | Heating & Cooling
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
Initial problem was that fire was taking long time to light, no spark being generated intermittently. Now Gas fire seems to be going off on its own when it has been on for a while. Fire is the hole in the...
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Feb 25, 2011 | Heating & Cooling
I have an old valor homeflame fire could you tell me how tha logs are put in position please
Here's a link to the Valor website home page.http://www.valorfireplaces.com/
Click on the Downloads tab and you may find the Owners Manual for your gas fireplace. It will show you how to install and arrange the logs properly. If you can't find the model you have, on the manuals page, use their contact information and call them.
Hope this helps you.
Feb 18, 2011 | Heating & Cooling
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
We have a Valor Model 466 Black Beauty OXYSAFE Fire, when you turn the sparker on the fire lights and you hold it down for a short time but as soon as you release the ignition the flame cuts out. We have...
It sounds as though you have a bad thermocouple. Replacing the thermocouple which senses the heat from the flame should correct your problem. The thermocouple is a safety device which when working properly sends an electrical signal to the main gas valve that your pilot lite is on and holds the valve in the operational mode.
Nov 04, 2008 | Heating & Cooling
Toys Logo
2,608 people viewed this question
Top Valor Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Valor Toy Expert? Answer questions, earn points and help others
