If your monitor uses a power supply (the brick that plugs into the wall, and then a smaller cord plugs into the monitor), then it's more likely the power supply that's gone out than the monitor itself.
Find someone with a multimeter to check the output voltage on the power supply. There will be a label on the power supply that says what the DC voltage (VDC) is supposed to be. If the meter shows no voltage when the power supply is plugged into the wall, then you just need a new power supply.
Do not try using another power supply as a substitute unless it is a specific match to your monitor. They vary widely by output voltage, etc. and using the wrong one could fry your monitor.
Hope that's helpful.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
