Turn on the console and navigate to the wireless settings screen. On
the Xbox, the menu path is "Settings -> Network Settings ->
Advanced -> Wireless -> Settings" On the Xbox 360, the menu path
is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the
wireless router. If your wireless router has enabled SSID broadcast, the
SSID name should appear pre-selected on the Xbox display. Otherwise,
select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the
mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your
router uses WPA encryption and the type of adapter connected to the Xbox
does not support WPA, you will need to change your router settings to
use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter
supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740)
only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a
connection has successfully been made with the wireless router, and the
Connect Status screen displays whether a connection has successfully
been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back!
Thumbs and testimonial are welcome!
