I don't remember what an f-du code stands for, but I will give you the next best thing. There is a list of the error codes and steps to correct the problem right inside your machine.
Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on). Once you remove the panel, turn it over. There in a sealed plastic envelope will be your technical manual and trouble shooting steps to correct them.
Good luck and drop me a note if there's anything else you need.
i have the same thing. du F code. I can't find how I can get into the front panel. How do I do that?
