This is an Epic 425 MX treadmill, model number EPTL88105.1. The treadmill doesn't operate at speed when there is weight on it, but lows down dramatically and somewhat erratically/jerkily. When weight is off the belt it tends to surge ahead before slowing back to the console speed. This problem occurred all at once and didn't develop over time. Concurrent with that, the machine also started to operate with a minor "rumbling" noise. I have checked the belt tension and it is within the manual parameters, nor does the belt slip when under load.
Thank you
It only does it at low speeds and then restarts,the belt does not slip. the unit actually shuts the motor offIt only does it at low speeds and then restarts,the belt does not slip. the unit actually shuts the motor off
You can't post conmments that contain an email address.
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free from www. fitness.manualsonline.com God bless you
you must have a Lamp for to help the screws. Unless the machine had not screws, must be adjusted to a pressure. You must use the screwdriver for to help to open the hood. see the video:
1. Hold the upper end of the treadmill with your right hand as shown. Using your left hand, pull the latch knob to the left and hold it. Pivot the treadmill down until the frame is past the latch pin. Slowly release the latch knob
I will strong that you see your owner manual. If you do not have manual. here is the web page for you download free right now:
