1999 Ford Taurus Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are possible causes for battery drains when parked for extended periods?
Anonymous
Level 3:
  • Ford Master 6,982 Answers
  • Posted on Jan 15, 2011
Anonymous
Ford Master
Level 3:
Answers
6982
Questions
0
Helped
2646710
Points
22782
Most cars now have many modules that incorporate "memory" systems that require a constant low voltage supply, including your radio. Most batteries will hold enough charge to last a month without going completely dead. Not sure what you consider "extended period".
If storing for more than a month, you could either put a 2 amp "battery tender" on it or disconnect the battery (but you need to know how to re-arm the security system so when re-connected it will start).
If the battery is going dead in a short time (two weeks or less) have the battery load tested after getting it fully charged. It may be good enough for day to day use but if it's not in really good condition it will get low quickly.
If you have a drain that's unusual, that will require going through the entire electrical system fuse by fuse 'till you find the drain source. At this point it can be so many things that commenting is foolish as testing is the only way to verify anything.
Testimonial: "Thank you."
2answers
How do i shut the power off it is draining my battery
Probably shorted put somewhere, making a connection and draining your battery.
1helpful
Have installed new batteries. New Alternator. After leaving 04 duramax parked for 3 days electronics are dead. Batteries were fully charged prior to parking the truck.
There is a very good possibility that there is a short in the wiring that is causing the battery to be drained when it is off. There are a few auto parts stores that can do a complete electrical system check and they can test the battery drain when the car is off. These problems are usually caused by a faulty relay which leaves a component on when the vehicle is off. Or there can be a wire shorting. However, finding a short is often like chasing ghosts. I would recommend going to advance auto. The electrical scanner they have there can detect battery draining.
3helpful
I parked the 2005 STS for few months. It won't start now even with a jumping cable. What can I do to fix the battery that has drained ?
charge the battery with a charger. newer vehicles with security systems will drain batteries when the vehicle has not been used for extended periods of time especially in cold weather.
Battery is drained by an internal short even with the key turned off on a 98 Mercury Mystique. No fuses are blown. With the battery fully charged it takes about 30 hours to drain the battery. Can a small...
Yes, it is very possible that a small internal short in the starter or alternator can cause this. Sometimes the starter wires can lightly touch and cause it to lose a charge. There are a number of things that can short and cause a battery to die over an extended period time. You should probably consult a specialist because it can be difficult to track down.
2005 suburban,I had the tires rotated and the battery died twice
Depends on how long he was trying to program the TPMS. With the engine not running and the ignition keys on, the day time running lights are on and the head lights are draining the battery. Next time your going to have the ignition keys on for a long period of time with out the engine running, set your parking brakes. Setting your parking brakes will keep your Day time running lights from coming on.
Battery keeps draining
are you not using it for three months at a time? if so it could something as simple as a clock draining the battery, i would disconnect the battery if you are not using it for extended periods of time
2answers
1996 tahoe won't start
try fittung a larger capacity battery this will help when you are parked for extended periods of time, but it does sound as if you have something draining the battery, try getting the alternater checked
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
