SOURCE: Downloading skype onto my acer aspire one netbook
For aspire one you need to download the Fedora 7 package from the Skype Website.
Afterwards, just do what your aspire asks you to do. When everything is installed, just press alt+F2, type in "skype", en press "Run". Skype will start up. That's it
SOURCE: MY Acer netbook model KAV60 no longer responds to wifi
Look below your arrow keys, near the bottom edge of the computer. There's a wireless indicator there, and on the edge itself there is a switch. You might have turned it off accidentally.
Hope to have helped :)
SOURCE: I have ACER Aspire One Model KAV60. Need to Identify Power supply
the coorect one should read an output of 19 volts, 1.58 A or very close to that. along with the 30W.
SOURCE: My Acer Aspire KAV60 netbook does not boot up. I'm
To install the drivers you need to go to:
Start Menu => Control Panel => Device Manager
On the top, there will be a toolbar and choose update the driver.
If doesn't work, mail me from
[email protected]
I'll be glad to help you ^^
SOURCE: acer aspire one kav60 will not connect to internet
check your lan driver if you are using cable.
right click on my computer
select properties
select hardware
then device manager
check network adapters
the device must be enabled or driver is present.
lastly check your cable or use other cable.
