You will need to remove inner door panel, either the handle itself broke where the rod connects,or the rod fell off or broke at the door latch, or the door latch lever bent or corrodded, the outer and inner handles use the same door latch but not the same mechanisms or rods to operate the latch. Once you remove the door panel and the inner dust shield with the window up look in the bottom of door for clips or a rod or broken parts. and note latch and handle for boken or bent and missing pieces. once you start looking it all becomes self explanatory.
