SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: hello sir, i have locked my
Since the lock code has already been changed and no longer to be remembered you have to seek a help with a certified cellphone technician that has an application software that unlocks Sony Ericsson phones.
SOURCE: I am having problems removing my google account
1. select menu -> settings -> applications -> manage applications
2. scroll down and click "Google Apps"
3. click the "Clear data" button (you will receive a warning, click OK)
4. go back to home screen
5. pull down the notification menu and click on the message "Your account must be updated"
6. follow the onscreen instruction until you get to where it asks you to "create" or "sign in", click "sign in" and enter YOUR new Google account info.
SOURCE: i am unable to unlock
then ur going to have to factory reset ur phone causing it to delete everything except what was on your sd card i just did it and it works hold the volume up + home button + search button for 5 or so seconds.
Maybe take the battery out or just power off for a while then restart and see if that helps you bypass that sign-in ?
