SOURCE: GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
SOURCE: How do I change the battery in the GE Simon XT
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
SOURCE: Remote touchpad for Simon XT stopped working
reprogram the unit to the Simon3
AlarmProfessor,net
SOURCE: GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
AlarmProfessor.net
