I find that a date stamp is available, but you have to select the picture while you are viewing it and it will do one picture only. You have to do the pictures one at a time manually.I find that a date stamp is available, but you have to select the picture while you are viewing it and it will do one picture only. You have to do the pictures one at a time manually.
You can't post conmments that contain an email address.
The date stamp has to be applied manually, one picture at a time while they are being viewed.The date stamp has to be applied manually, one picture at a time while they are being viewed.
I have a Z981 myself. I just set my camera as you did (to "A") but did not experience the issue you mention?
Just to be clear, remember that setting the camera to "A" means "Aperture priority", meaning that you can control the lens aperture (with the "jog dial" on the top of the camera) and the camera will automatically set the shutter speed to create a proper exposure. "A" does NOT mean automatic exposure control. You must use "P" (Programmed) mode to make the camera make all the decisions about shutter speed and lens aperture.
I am including a web link to the User Guide for the Z981. You might want to revisit the Guide to make sure you are using the correct settings for your pictures.
BTW, I like my Z981 quite a bit, especially the zoom. I've taken some great pictures with it.
Did you install Kodak Picture Easy Software already?
To transfer pictures from your camera to the computer, you need this software (and the driver that comes with it)
If you done't have the software, try to get it with Kodak, or use an external memory card reader, to transfer the pictures from the memory card to the computer. That must work.
The camera won't deface your photos by printing a bunch of numbers on them, but it does store the date and time (and a lot more) with each photo file. You can choose to include some of it when you print the photo. Depending on the program you use, you may be able to print the date on the photo, in the margin, or on the back. Please refer to the documentation for the particular program for details on the procedure.
Download or transfer the pictures to a folder in your computer - preferably your "Pictures" folder. When you write the Email, "attach" the picture to the Email by locating the Picture folder in your computer and selecting the pictures you want attached.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
