SOURCE: nokia 6820 black screen
you have a damaged screen. they generally go black when they have been cracked and the liquid crystal has leaked. the LCD can be replaced, but if it also has a tired battery, it is probably not worth repair. If you want to replace the display,you need the correct tool to remove the screws from the chassis internally, and the new LCD can be purchased from http://cellink.com.au/products/ They have the tools and parts to repair just about any phone. Good luck. A "fixya" rating for my advice would be great :)
SOURCE: Display on LG VX8600 screwy
well most probably your lcd screen is fualty you can fix this yourself with a t6 torx screwdriver and a new lcd screwdriver that will cost you around 15 pound on ebay , hope i helped
SOURCE: Nokia N70 Screen gets white blank
check your battery! i think you are using duplicate battery! put original battery to your mobile! again the problem came mean install new software and format your mobile
SOURCE: Blue screen on main display
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
SOURCE: phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
