Remove dispenser & filter from top of agitator. Down the bottom of the center of the agitator you will find a plastic cover. Pull this out with a bent piece of wire formed into a hook. Under the cover is a 10mm hexagonal head bolt. Using a long extension & 100mm socket you can undo it to remove agitator.
1.
Rotate nozzle to the vertical position. Lift off front cover.
2.
Remove the two bottom plate screws.
3.
Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4.
Remove agitator and used belt from nozzle.
5.
Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6.
Attach belt to motor pulley.
7.
Replace bottom place by first hooking it to center tab on inside of nozzle.
8.
Reposition screws and front cover.
Hope this helps!
