Question about Nintendo Wii Console
My wii remotes are not responding to my wii unless i am within a foot of the receiver anyone know why? and how to fix it, thanks
    Sergeant:
  • 147 Answers
  1. Access the Wii System Settings
  2. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  3. Choose "Sensor Bar " and select "sensitivity"
  • Use the Wii Remote to get the cursor to get the two white dots in the test field.
  • If you see two blinking dots, then the sensitivity is currently set correctlyIf you don't see two blinking dots (they don't have to blink at the same time), adjust the sensitivity with the + and - buttons of the Wii Remote until you see two blinking dots.
  • Select "Confirm" to save the setting.
Please note that the higher the sensitivity setting, the more sensitive the Sensor Bar becomes to sunlight and various light sources. This may impact the operation of the Wii Remote. The initial recommended distance for using the Wii Remote Pointer is 3 to 8 feet from the Sensor Bar.
Seeing more than two dots?
If you see more than two dots on the Sensitivity screen, then the Wii Remote is picking up on additional light sources. Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Posted on Jan 16, 2011
6ya staff
SOURCE:
My Samsung 40" 8 series LED has stopped responding
Look for anything blocking in the sensor panel of the TV, like glue, gum or any other sticky substance, which might obscure communication. If these are ok, the sensor part has to be looked into.
Aug 21, 2012 | Televison & Video
My AT&T U-Verse remote control is not responding anytime I click it. Does anyone have a solution?
Hi Yoav! The AT&T remote control from U-Verse can be quite buggy sometimes-- trust me when I say you're not alone.
Thankfully, the fix is quite simple and should only take you a couple of minutes. If this doesn't work you need to get a replacement remote.
All you have to do is turn your receiver off, keep it off for about a minute, and turn it back on again. For whatever reason the U-Verse remote and your cable box will intermittently lose the ability to interact with one another, but going through this type of "soft reset" will usually solve the problem.
I know AT&T has had this issue for awhile but it looks like they haven't been able to solve it yet. Big surprise right?!?!
Mar 01, 2012 | AT&T UVerse
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another wii...you need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wii remote
Is your sensor bar connected to the Wii? Check the sensor bar cable for cuts or severe bends (like a V shape) as they might cause the detection problems with the Wii-mote. A cheap fix is to put lit candles in front of your TV and see if the Wii-mote picks it up then.
Jul 27, 2009 | Nintendo Wii Console
Our nintendo wii remonte does not respond to the wii console
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Mar 10, 2009 | Nintendo Wii Console
My nintendo wii has frozen after start up screen frozen on menu
disconnect power to nintendo and also the tv, replug should be ok
Feb 19, 2009 | Nintendo Wii Console
Wii Guitar - buttons not responding
Just So You Know You Can Exchange It If You Got It At Wal-mart.
Hey Michelle How Are You?
I Know About The Constant Problems On The Wii Remotes But Have Not See A Whole Bunch On Them. I Am Gonna Attach A Youtube Video For You To Watch And I Want You To Try What Hes Done.
Let Me Know Your Outcome.
Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 18, 2009 | Nintendo Guitar Hero: Aerosmith for Wii
Wii remotes not responding to Wii console
Jan 06, 2009 | Nintendo Wii Console
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Wii remotes dead
Problem in the sensor bar. Remove it, invert it several times, refix it and resynchronise.
Sep 03, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
132 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
