I have a Sansui LED T.V./monitor Model HDLCD1909, every time!I've turned it on here today it just seems dark n over redded, also I do believe that I had it working a short time last night, I have NO REMOTE and want to 'Hard Rest entire Television System.
Obviously you could get one from sansui or better yet try ebay they probably will have one it may be a few weeks until one or more show up. Some links to try:
Check and replace its back-light inverter board. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/Electro help
My sansui LCD tv is getting on after plug in to power supply but it is not getting on after switching on the remote/tv ,display is not coming pls help me
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Hello Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600. If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
"Barn?"
If you are not close to a metropolitan area, no indoor antenna will do much.
A well-designed rooftop antenna, preferably with amplifier will get usable signal from 75-100 miles away if there are not too many hills between.
PBS stations are scattered around everywhere so those are some that can be had when other, more powerful network stations service densely populate areas and don't care much about rural areas.
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
