I would not spend the time or money upgrading this processor. If you wish to, you could max out the memory. The 751n originally came with winXP The hardware architecture is well past its useful life regarding upgrades. Go on NEWEGG.COM Find the refurbished Desktops. Look for something WIN7 and at least 250GB hard drive with 2 or more GB Memory.
The cpu is non- upgradable as it is soldered to the motherboard.
SOURCE: location of s/pdif out pins
one of 2 places bottom rear of board or right in the middle of board in the back near the audio plugs
SOURCE: I have Acer Aspire-5570-4765 laptop
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
SOURCE: I have an Iomega SuperSlim
No the movies should play even with 128MB of ram, that is not the problem. It seems like your missing a proper dvd viewing program and video decoder.
I'd suggest that you install FFDSHOW video decoder and VLC media player.
FFDSHOW is available for download here http://www.afterdawn.com/software/audio_video/codecs/ffdshow.cfm
Download and run the program, in the setup all you need to do is to click next until the setup finishes. and then close or click on finish, it is done and can be forgotten. it will work in background when movies are played to decode to video.
Now for vlc media player. http://www.videolan.org/vlc/
Download and install the program just like ffdshow. Start the program with a dvd in the drive, click file open disc or dvd. make sure the drive letter is correct (letter of the external drive) and click play. or OK or Open, I don't remember exactly what it reads.
The dvd should being playing.
Let me know how it works.
-ekse
SOURCE: HP Pavilion 751n Pentium r 4 1.8 GHz Ram: 1G DDR
you can use Prescott 2.4 it will suport .
purchase from bellow the link.
http://shop.ebay.com/i.html?_nkw=2.4+prescott+&_cqr=true&_ipg=&_nkwusc=2.4+preescort&_rdc=1
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Testimonial: "I thank you very much Sir! very kind of you! cheers and god bless!"
SOURCE: Hi, I want to upgrade my
It will be compatible but it is recommended, you use same type of modules(RAM)
ie 256 MB + 256 MB
1GB + 1GB
Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
error on page! wrong section! please move to PC upgrade section! thank you!
