Expert
- Posted on Jan 17, 2011
Re: HOW TO PLAY DVD PLAYER WITH THE TV
Instructions
Things You'll Need:
DVD
RCA, component, or HDMI cable(s)
Decide
what type of connection to use. Look at the back of your DVD player. It
should at least have RCA (red, yellow, white) output ports. It may also
have component out, S-video out, VGA out, or HDMI out. These
connections vary in picture quality and price, HDMI being the most
expensive and providing for the highest-quality picture. Whichever type
of connection you decide to use, you also need to verify that you have
the same connection on your TV. Flat screen TVs typically have more
connection options than other types of TVs, so you should at least have
component, RCA and HDMI inputs.
Connect
the DVD payer to the flat screen TV. Take one end of the cable or
cables you decided to use and connect to the output on the DVD player.
The other end should be connected to the corresponding input on the TV.
Video input connections are usually found on the sides of flat screen
TVs. Once the DVD player has been connected, you are ready to use your
DVD player.
Check
DVD player functionality. Tune your TV to the input that you used for
your DVD player by pressing the button on your remote labeled "input,"
"source," "TV/video," Source select," "TV/AV" or the like. For
instance, if you used an HDMI cable plugged into your TV's "HDMI 1"
input, press the input selection button until you see HDMI 1 on the
screen. Power on the DVD player, insert a DVD into the player and press
play and you should now see a feed from your DVD player.
