You best bet is to pull the hard drive and attach it to another computer. This will allow you to copy the infomation you are worried about to another sorce. Most computer retailers that offer services will have a back up service and can do this for you. The average cost in my area for a back is $100.
Once you have the computer repaired, make sure you back things up. If you are worried about loosing something back it up twice. External hard drives are reasonably priced, and most computer have some kind of optical burner.
If iPhone won't turn on, or the display freezes or doesn't respond
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets: Try This: 1. Remove Sim Card 2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears 3. Replace Sim Card 4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this: 1.) Shut down the iPhone 3G. 2.) Start up iTunes 3.) Hold down HOME button on the iPhone 3G 4.) While keeping the HOME button depressed, plug in the Sync cable 5.) A message will pop up to ask if you want to reset. 6.) Just click YES and the reset process should start.
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
The monitor you have has bad components on the circuit boards inside. This is a classic problem with all LCD monitors. I rebuild them on a daily basis so I recognize the symptoms. I would suggest finding someone who can do component level repair on the circuit boards inside. I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
