Even though it is not activated, one or few of your current applications dialing a data call over your network. If that is not the case, may be your service provider keeps reducing your account due to a problem of theirs.
Other than that, it may be an unwanted software which makes the call(I do not like to call this a virus)
I'd suggest you contact your service provider and talk with this.
SOURCE: gprs
firstly check that whethere ur phone provides gprs ,if yes than talk to ur network provider executive and tell him to activate gprs connection
SOURCE: slow grps speed on nokia 6600
try to connect the phone to pc using a cable, that should make the speed abit faster but generally, connecting internet from phone to pc makes the connection slow
SOURCE: can not activate gprs on china mobile
to connect to the internet or set up email or to send mms you must activate the GPRS first from your
network provider ...The best thing you can do is to contact the
customer care of your network provider and ask for the activation of
GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you
will receive the gprs settings(profile) also ... make sure of the
charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if
the customer people tell you that your handset is not compatible for
the receiving of the profile settings then you must tell them to give
the manual settings(includes ip address,APN,etc) so that you can only
create the profile and input the information given by the customer care
people...
if you have already subscribed the GPRS then call the customer care of
your network provider & ask for the settings by telling your model
of the handset ..
SOURCE: gprs settings
for activating gprs you should contact your service provider.they will send you gprs settings and just by opening it you can activate gprs in your mobnile.
# Basic Requirements:
1. A Web Enabled Phone that can be connected to the PC using a data cable, bluetooth or infrared
2. A GPRS activated mobile connection
# Procedure:
1.GPRS activation
In BSNL the balance should be more than Rs. 50 for the GPRS to remain activated. To activate GPRS an sms has to be sent: "GPRS E" to 53733 [removing the quotes]
The usual cost is 2 paise/ Kb. But BSNL has an offer which provides 30 days unlimited net for Rs 189 [by easy recharge from an BSNL outlet] and probably Rs 51 for 7 days unlimited net.
2.Connecting the phone to the PC
The phone can be connected to the PC using the USB data cable, bluetooth or infrared with the help of the driver tools provided with the phone. Hence the phone will be ready to be used as a USB modem connected to the PC.
3.Settings for the Modem on the PC
Start > Settings > Control Panel > Phone and Modem Options > Choose your modem > Click Properties > Choose tab Advanced > At Extra initialization commands, enter code:AT+CGDCONT=1,"IP","www.e.pr" > OK
4.Setting up an internet connection
Though an internet connection can be setup for Motorola MotoRokr E6 using the PhoneTools software provided with the phone, in any usual phone a new connection has to be setup using the DialUP Networking function of Windows using the following process:
Start > Control Panel > Network Connections > New Connection Wizard > Next > Connect to the Internet > Next > Set up my connection manually > Next > Connect using a dial up modem > Next > Choose your modem > Next > Type "bsnl-gprs" > Next > Type "*99#" or "*99***1#" or "*99***2#" or "*99***3#" > Next > The Username box can be left blank > The Password box can be left blank > The Confirm box should left blank too > Next > Finish
While using the setup process through the mobile PhoneTools the following data may be used:
Username : <blank>
Password : <blank>
Access Point Name[APN] : www.e.pr
5.Browser Configuration
In the browser used on the PC, certain proxy configuration must be made in the "Tools>Options>Advanced>Network>Connection Settings" button for Firefox and in the "Tools>Internet Options>Connection Settings>DialUp and Virtual Private Network Settings>Settings" button for Internet Explorer :
Proxy server : 192.168.81.163
Port : 8080
But sometimes this process works without this proxy configuration thus providing better speeds.
Now u r ready to go, connect the net and surf your way through. The net though gets connected at 115.2 Kbps but you will get nothing close to it. Though this net is good for surfing and casual downloads but sites loaded with heavy images and graphics are hard to open eg. Orkut etc. Hope you find this article useful.
