Toshiba page is the BIOS first boot page and should boot from either the DVD ROM or the CD ROM then the hard drive. I would go into the BIOS and set it to boot from the hard drive first it is seeking the ROM drive and stopping. If it does not boot to Windows from the hard drive then you have lost the initial boot file.
Or they are corrupted and you will need to restore the computer back to factory settings. You should have the software that came with your lap top it is not really a problem if you follow these instructions. If you have never done a reboot it is strongly advisable to get someone who has done this before to do it for you. I hope that you saved your important documents and files pictures etc to an external source first.
There is another option to watch the screen when it boots see if you can use F10 or F8 or F1 or F2 to get into safe mode during the boot process. It should tell you which key you can use to get to setup from there you can change the boot device process under boot options to hard drive first boot or it may tell you boot order key information. Whatever it is get there and change it to hard drive first boot. I would highly recommend a repair shop or a friend who knows what they are doing if you do not to handle this problem. John
