If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
make tv off using stand by on remote and again power on it by remotr s.mode will disappear need to replace eeprom ic with original is provided by philips only
Yes it worked for me by doing blw : Press : 062596 & menu button to open service menu. Then change blw values on option tab : op1 : 128op2 : 215op3 : 065op4 : 000op5 : 192op6 : 129op7 : 112 then press menu button & power button on remote & plug-out the main cable from power socket for 10 seconds. Then switch on the unit for result...............
