Mine also. What did you end up doing?
Could be as simple as a coin rubbing on the drum or as in mine... It was a bad drum roller which had came off its spindle and the drum was scrapping on the shaft. You may need to disassemble and remove the drum to have a better look.
Mine was a bad roller which called for 35001136 or W10177428 which range from $30-$40.. But after further surfing i found out that Samsung DC97-16782A will work and its much cheaper, $12.00 ea.
3 year update: I decided to let my dryer run it's full cycle. After a few minutes.. It worked just fine. I'm still using it. '=)
