Hi, To access the recovery partition on your Acer computer for recovery, follow the steps listed below.
1. Power on the computer 2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery. 3. Once eRecovery has loaded, click Restore to Factory Default Settings 4. Click OK to continue 5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes). 6. Once eRecovery has run, press OK to reboot unit
Note that all data will be lost during this process and your computer will be brought back to it's original factory state and settings.
Laptop Recovery Instructions If you cant boot into windows
1. Power on the machine 2. At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key
simultaneously to start Acer eRecovery 3. Once eRecovery has loaded, click "Restore to Factory Default Settings" 4. Click "OK" to continue 5. From here, the eRecovery process will update all the data on the C: drive
and restore a fully functional factory image (approximately 10 minutes). 6. Once eRecovery has run, press "OK" to reboot unit
If you can boot into windows
Click "START"
All Programs
Acer/ Packard Bell/ E-machine recovery
Select "Recovery management"
Click "Restore"
Click "Fully restore to factory default"
NB: This process takes about 15 to 20 min
all you have to do is reset your phone if your phone is working and not asking for security code than you can update your phone using nokias pcsuite when your update your phone it will restore all ur setting to factory default and your securtiy code too will set to 12345
Soft Reset (*#7780#): This is a normal reset. It will load the original settings from the phone's ROM. However, it will retain the user's own data. Like images, music, installed applications etc.
Hard Reset (*#7370#): This method completely reformats the C: drive (Phone Memory). All the user information will be deleted. Like images, music files, installed applications etc. Hence, the phone is set to the default factory settings.
OR
Switch Off the device. * Press and Hold down the keys Green/Talk + 3 + *. * Switch On the device. * If everything goes well then you will see "Formatting" screen.
On performing any of above methods of formatting the phone, device will ask you for a security/lock code. Default code is 12345.
The link above will explain how to restore the phone to its original condition. This effectively reinstalls S60. It also wipes out everything else on the phone so be sure to use Noia PC Suite to back up what you need to keep and to restore it after the reinstall of S60.
