Acer 4220-2346 Notebook Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to repair a broken hinges and monitor case
Anonymous
Level 3:
Genius:
  • Master 1,288 Answers
  • Posted on Jan 18, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1288
Questions
Helped
286041
Points
4123
3 Related Answers
ROD GANDY
  • 1602 Answers
  • Posted on Feb 12, 2009
SOURCE: replace the screen hinges
LOOK UNDER NIETH THE FEET OF THE COMPUTER AND YOU MAY FIND SOME SCREW SLOTS, OR A MANUFACTURE LABEL IS PLACED OVER A SCREW HOLE TO KEEP PEOPLE OUT OF THE COMPUTER.
LOOK IN THE HARD DRIVE, BATTERY AREA, COOLING FAN AREA FOR EXTRA SCREWS,
THEY ARE SNEAKY WHERE THEY HIDE THE SCREW HOLES AT
LAST BUT THEY MAYBE SNAPPED TOGETHER AAND VERY HARD TO TAKE APART.
GOOD LUCK
ROD THE CANDYMANGANDY
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Sep 03, 2010
SOURCE: how to repair broken hinge on monitor
It's can't be repaired, it has to be replaced. You'll need to replace the hinges and other necessary parts.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Azrael SRL
  • 11800 Answers
  • Posted on Nov 05, 2010
SOURCE: I have a broken hinge
Get a good epoxy glue, if you follow the instructions to the letter it will be like it never happened - of course you will need to dismantle the laptop for easy access and you must have all the broken parts.
How to repair a broken lower door hinge?
You may need to remove the microwave off the wall but lets try this first. Unplug the micro and then remove the screws around the bottom cover plate. The cover should drop down--watch the wiring to the light system mounted to the cover. Now look at the bottom hinge area. Can yo see and access the screws to the hinge??? Should be 2 or 3 screws. If you can get to them then you can change the hinge there. Tape the door in place so it doesn't drop while doing the repair. If you can't see the screws, you may need to pull the micro off the wall and remove the outer case to do the repair. In some rare cases the hinges are welded to the case and not replaceable.
2helpful
Monitor flip broken
Hinges would most likely have to be replaced, along with possibly the bottom case of the laptop. Hinges are usually sold in a pair, costing around $100, the bottom case if its needed, usually costs around $70.
i would advise you to take it to a technician who specializes in laptop repair (Your local Staples may be able to help you), and get a quote on repairing it. I would expect labour for that job to be around $100-$150 as well (if you're not doing the repair yourself).
Replacing laptop hinges
There are 2 set of cable that run from the display to the monitor, be very careful with it. In most cases, to remove these cables you need to disassemble the whole laptop. Now, since you are on Y changing the hinges, I think you can do it, just don't pull on the monitor too hard, and it needs to be place on a flat surface very close to the laptop. It's not that hard, you just need to be careful, that's all.
WHEN COMPUTER STARTS I GET A BLUE SCREEN AND THEN IT REBOOTS
A very dark blue screen on a laptop that otherwise appears to be "on" is a sign that the backlight on the screen portion of the computer may be burned out. You can test this by shining a flashlight on the screen. If you can see your desktop icons, the backlight is burnt out. Replacing a bad backlight is not a do-it-yourself task unless you are comfortable doing delicate electronic repairs and have the design schematics for your model in hand. Your safest course of action will always be to take the laptop to a professional repair depot. There is one alternative repair option available if you're not comfortable doing surgery and a trip to the repair shop is not in your budget. Replace the entire screen module, case and all.
Doing Surgery Yourself
1.Remove the battery from the laptop. With the laptop model schematics in front of you, use the small Phillips screwdriver to separate the monitor from the laptop base. The schematics will indicate how to uncover the monitor hinges and free the monitor. Handle the screen gently because it will still be tethered to the base by a group of wires.
2.Remove the plastic case covering the "power bar" on the upper part of the laptop keyboard base. Refer to the schematics to find the way to release this cover and lift it off the keyboard. You'll see a group of fine wires leading back to the monitor. Unplug this cable so the monitor is now free from the base.
3.Follow the schematics to remove the casing covering the monitor screen. Be forewarned that the design of a laptop monitor "under the hood" is complex and delicate. Don't force anything. Don't experiment. Take frequent photographs of each successful disassembly stage so you can have some hope of getting it all back together again correctly.
4.Find the slim fluorescent backlight instrument behind the glass layers of the screen. Unplug it from the tiny cable receptacles and remove it. Insert the fresh backlight fixture and reconnect it to the cable plug.
5.Restore the screen assembly and the casing using the schematics and your reference photographs. Plug the screen back into the laptop base at the power bar. Don't reattach the screen hinges to the base until after you have tested it by booting the laptop. If the test is successful, turn the laptop off and connect the screen to the base unit at the hinges.
Alternative Repair
1.Purchase an entire screen-and-case assembly for your laptop make and model. Many intact assemblies are available online for reasonable prices. You will usually pay slightly less for an entire screen-and-case unit than you would for a professional repair on just the backlight alone so this could be an economical alternative for you. You can save even more money by purchasing as "Used but Good" unit, rather than a new unit.
2.Remove your old screen following the previous section's Step 1 through Step 3.
3.Plug the new screen-and-case unit into the laptop base. Follow the schematics and your photographs and thread the monitor wires through the hinge passes. Restore the power bar cover.
4.Test your replacement repair by booting the laptop. If the screen looks normal, shut off the laptop and reattach the new screen to the base at the hinges. Restore the hinge covers.
I hope you find it very helpful. Thanks.
1helpful
The right hinge on the monitor is broken and the the monitor does not work at all. It appears the hinge locks on two hoop-like catches, and one of the two is broken. Thank you
hello your screen will not work because the wirering that comes from the laptop to the monitor has either broken or came away from its plug it would be best to leave it into a repair shop i hope this helps you goodluck
1helpful
How to repair broken hinge on monitor
Good luck.
1helpful
Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
