There is a drain pump that is separate from the main pump on most kenmore elites. There is also a check valve that could be stuck open. 8 of 10 times, however, if the machine was working fine and is now not fully draining, this is due to a drain hose pluggage or kink somewhere between the drain pump and the discharge into the sink. I've seen grease totally block the discharge into the sink trap and cause this problem. This should be thoroughly checked and must be 100% clear for the dw to drain properly.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
heatman101
