check if this is happening from all trays... if such clean the paper feed rollers... if still happening clean any other rollers in paper path... if still happening then you have a bad sensor that keeps tripping at the wrong time... but more than likely this is only occuring with one tray... clean your feed rollers and it should be ok... still not ok... then replace feed rollers... there is also the possibility that your fuser is shot... your can tell if your fuser is shot if... when you put your hand near it... it doesn't feel like it could burn you... if you can actually get to touch it and its cool to the touch... then you got a bad fuser...
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Well what you need to do is do a rest on the printer.That should solve the problem.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
