Tuner is gone. An external tuner may be a viable alternative. Go to ebay and check out what is available. eBayeBay
SOURCE: no picture or menu
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
SOURCE: Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
SOURCE: Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable.
When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive.
Depending where you are and the type of antenna you use you probably could pick up some digital channels.
Let me know if this helps and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: how do you watch free cable channels on a sony
If you are connecting the cable directly to the TV with no cable box, you'll select Home on the remote control. This will put the menu on screen. Scroll down until you find the Channel Settings option. Set the Cable category to On, Select Auto Program to automatically scan for all analog and digital channels. You can then customize which channels you want to remove when scanning channels.
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
