Apple iPad 32 GB WiFi Tablet PC Logo
Posted on Jan 18, 2011
How can i receive outlook mail in an ipad which i was previously receiving on my pc
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1278
Points
22
Go into the mail app then choose outlook or something similar( I haven't done it in a while) Then set up your user and you're done!
Can recieve but cant send
Unable to Send Email? Check These 5 Things - rackAID
https://www.rackaid.com/.../cannot-send-email-how-to-fix-email-sending...
This likely means SMTP authentication is not enabled. If you get a relay denied error and your password is correct, then SMTP authentications is likely not correct. Often, email users with this issue can receive but cannot send email.
I am receiving email fine, but I cannot send messages ...
www.gn.apc.org/.../i-am-rec...
Association for Progressive CommunicationsThe usual symptom is that Thunderbird will try to send for about 20 seconds before giving up with "Sending of message failed. The message could not be sent ...
Are you able to receive emails but not send? - Hostgator.com
support.hostgator.com > ... > Email > Email Troubleshooting
If you aren't able to send email, this usually means one thing: your internet provider is blocking you from using anyone's outgoing mail servers but their own. ... so that theycan monitor outgoing email on their network in order to prevent spam.
Problems Sending Mail - Receiving is Fine - InMotion Hosting
www.inmotionhosting.com > ... > Email > Email Troubleshooting
Jan 14, 2015 - Outlook 2013, cannot send mail, but can receive mail ... I haven'treceive any mail since yesterday and I can't send mails too... can you help me ...
I can receive emails but i can't send them. ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Can not receive email on iPad
Please be more specific. If you are having trouble with the mail app, you can simply access your email provider using safari, or download a third party app. For more help, visit http://www.apple.com/support/ipad/mail/
How do I Sync Outlook from my Desktop Computer to my Apple IPAD?
To sync e-mails to your iPad, you must put the e-mail account details directly into the mail app. This is because Outlook is merely an application to download and read e-mails.
To add an e-mail account to your iPad:
1. Tap the Mail icon at the bottom of the home screen on iPad.
Step 2. Then tap to add type of email account that you want at add among: Microsoft Exchange, Mobile me, Gmail, Yahoo Mail, AOL or others. For example, if you want to add a Yahoo mail, just tap the Yahoo mail as follows:
Step 3. Then enter login details for selected email account type.
It will configure automatically and you should able to send - receive emails.
1helpful
Can you synchronise Outlook 2010 contacts with an iPad?
If you sync with an Exchange server of some kind, your outlook contacts should be synced to that server. If that is the case, add the Exchange server to your iPad under Settings>Mail, Contacts, Calendar>Add Account. Then, make sure the slider switch beside Contacts is set to 'On'. If you are not connected to an Exchange server, you can always try syncing to another service like Google Contacts and use that service's sync functions to bring the contacts on to your iPad.
Hope this helps, Alistair
I have just got an iPad 32GB. I wish to move all my emails from my PC to the iPad i.e. my Outlook mail folders, all the emails in those folders etc. Can this be done ?
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
How to use out look on i pad
The answer is yes, You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
  • If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
  • Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
  • Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
  • Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
  • Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
  • Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
  • A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
Aloha! i just got a new ipad and would like to
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
2helpful
Syncing Outlook 2007 email with iPad
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
