You can either use the supplied A/V and USB Multi connector cable for connecting the Camera to the TV. Connect the Yellow cable to the Yellow port on the TV for Video and the Red and White for audio. Then select the proper input on the TV where the cable is connected.
You may also connect the HD Out of the Camera to the HDMI Input on the TV using the compatible HDMI cable for the Camera.
Before connecting the Camera to the TV, you may have to change the settings in the Camera depends on the TV type.
1. Component Settings from the Main Settings 2 Menu of the Camera should be set to HD or SD depends on the connection. Also depends on HDMI (HD) or A/V (SD) video connection.
2. Video Out Settings from the Main Settings 2 menu of the Camera should be set to NTSC or PAL depends upon the color system of the TV.
Try changing the settings in the Camera and connect it to the TV to view the images.
Thanks for using FixYa.
