LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whre can i find a LG flatron w1934S assembly Manual? (need to change / repair the backlit)
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jan 19, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366109
Points
33650
More likely to be bad caps as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
Make sure to replace them in a set with good caps with low ESR nad 105c rating.
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=W1934S&kategoria=&kat2=all
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
How do i increase my moniter brightness
assuming you know about using the buttons on the front and it has not worked i would guess the internal lamps are faulty you could just replace the monitor or try and repair it i have linked the service manual
2helpful
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
2answers
Hi my LG w1934s LCD monitor suddenly not working it screen is full with color lines even I disconnect the VGA cable from the system unit the screen is not change the color lines are as it is what can I do...
That have not simple solution better take it to a tv repair shop, you already disconnect the data cable and discard the possibility of computer problem.
The Monitor must have in the menu a reset configuration option but I doubt it will help, its time to get it to a repair shop.
2helpful
I want lg flatron w1934s drivers.please tell me how can i search them.
Hi, i would search on DriverGuide.com.... its the safest place. Most other driver download
sites are infested with pests that can bug you to no end.
1helpful
My lg flatron model w1934s was working fine but now it will not come out of power saving mode at all. What should I do?
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
2helpful
Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
