SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
SOURCE: LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
SOURCE: replace seal to front loader LG WD-8016C
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
SOURCE: door wont open on LG WD-8016C
mine either. The handle seems to break easily. Try getting a butter knife and pushing in from the left hand side, this will undo the latch.
