Hi You can try to reset the control, to do this press and hold
the SENSOR DRY & TEMPERATURE button for 10 seconds. If this will not reset
then the control board is bad and should be replaced. Hope this helps...please
post back for further assistance. Daniel
Hello, If
your dryer won't start, you can troubleshoot the problem to determine
whether you need to hire a repairman. Some repairs can be done without
help, while others are trickier and may require a professional. Start
with the most obvious possible causes and work your way up.
Check the power
Hope this help?.
Test the door latch. If it won't catch, that could be the answer. If the door closes securely, check the door switch next.
The
door switch turns the dryer off when the door is open. If it's not
working, your dryer won't start. It will be located in the front panel
near the door opening. Remove it and test with the ohmmeter. If it's
good, replace it and move on.
The start switch is another common
reason dryers won't start. Remove the screws at either end of the
control panel and flip it forward. You may have to remove the endcaps
first. Remove the start switch and test with the ohmmeter. If the
switch is good, put it back together and move to the back of the dryer.
Once
you have the panel open, the first thing to check is the thermal fuse.
This is a small unit attached to the exhaust duct of most dryers that
is designed to blow if the dryer overheats. Test the wires using the
ohmmeter. If the thermal fuse is blown, you should also consider
replacing the thermostat.
The thermostat will be attached to the
ventilation system. Remove it and test the wires with the ohmmeter. If
it's good, it's time to call a repairman.
The motor is the most costly part of the dryer. If the motor is burned out, the repair can cost several hundred dollars.
Good luck and thanks for using fixya.
All power is good, this I know because I was able to run some diagnostic tests. The door switch, sensors are good. Control panel seems to all light up also.
I bypassed the thermal fuse and the dryer kicked on. So it looks to be the thermal fuse.
Thanks
