Question about LG M1962D Monitor
What is combination for entering service menu on LG M1962D?
  • LG Master
  • 7,733 Answers
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Posted on Jan 19, 2011
    New Friend:
Power Button Lock
This mode locks the power of the LCD dislay in the ON position.
• Power Button Lock: Press and hold [1] and the down arrow for 10
seconds. If the power button is pressed the message Power Button Locked
will display for 5 seconds. With or without this setting, after a power failure,
your LCD dislay's power will automatically turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow again for
10 seconds.
Posted on May 03, 2016
6ya staff
SOURCE:
Fallo en pantalla v3.16.0
hola, la pantalla de mi tv se ha quedado en blanco y un codigo que pone v3.16.0 recorre la parte superior de la pantalla. que devo hacer?
Nov 30, 2012 | LG M1962D Monitor
Where can i find a driver for LG Flatron M1962D?
If you are using it as a computer monitor, it does not have a driver, it relies upon your video card to have the compatible format. This is consistent when using an HD TV as a computer monitor.
So Identify your video card, download the driver, even if it is an older operating system, the driver will still work if you are on the same basic architecture- 32 bit versus 64.
Jan 29, 2012 | LG M1962D Monitor
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
Can i play movies as well as music via a usb memory stick for my lg flatron m1962d-pc monitor
The USB port on this monitor is just the USB hub than expands your PC USB port to the monitor (USB port of the PC will have to be connected to the USB in of the monitor). It is not a stand alone USB port.
Feb 17, 2011 | LG M1962D Monitor
Hello! how can i get a code to open LG cyon.i m from nepal.i had made one way by searching codes from net.but i cant do phone so what can i do??
1-Press 277634#*# phone will enter Service Menu
2-Select GCF Setting
3-Select GCF On
4-Phone reboot and unlocked working with any sim
Note:This Solution working with only old firmware version
Phone lock,user code
- Press 277634#*# phone will enter Service Menu
- Select Factory reset
- Phone reset and reboot
- Phone unlocked (All phone defaul setting).
Unlock LG KH1800
- Press menu - 0 (hold) enter code: 147359
- Phone enter Service menu
- Select GCF Test - Select Rel.99 or Rel.15 phone reboot and unlocked
Sep 16, 2010 | LG Cyon
Connect lg m1962d for freeview
Hi, you should be able to receive it. There should be a button, either labelled TV or DTV, that will flick between normal ariel viewing mode or DTV.
Have you tuned everything in?
You should be able to get all channels.My Father in-law uses a seperate box with an indoor arial and gets everything crystal clear.
I fyou need more help - then please ask.
Tony
Jun 06, 2010 | LG Televison & Video
Need programing codes for LG-VX11000
There are three programming/service menus I know of. To access all of these, you dial the number and hit send. Some you need to put in a second code afterward:
Programming Menu:
##PROGRAM11000
(hit send)
Enter: 000000
LG Service Menu:
##LGSERVICEMENU
(hit send)
Enter: 000000
Test Menu:
##SERVICE
(hit send)
Be CAREFUL, you can brick your phone with some of these options (i.e. kill it).
Oct 27, 2009 | LG enV Touch VX11000 Cell Phone
Unlocking LG KG800
A LG KG800 orange chaklete mobile set sent to me by one of my friend from england to Pakistan when I put a sim in it becomes lock and wants NCK code plase guide me. Thanks.
Jan 15, 2008 | LG KG800 Cellular Phone
LG M1962D Monitor Logo
1,700 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
