Search the internet for "Brother error E6."
An E6 message appears on the panel Brother
E6 ERROR
Brother CE 4000 tangled bobbin thread error E6 SEWING IN GENERAL
Hello, did you ever figure out a solution? Im in the same boat....
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
