SOURCE: vehical toyota four runner shut engine off then
either get that remote or try taking off negative battery wire off again. check with toyota if there is a bypass switch under dash
SOURCE: I replaced my battery in one of my remotes the
reprogram remote. turn key to position, push valet button 5 times and then push the lock button on remote
SOURCE: I have a dead battery. when I try to jump start
while the alarm is goin off tyr and rearm and disarm the alarm 3 times.. then start the car.
Turn ignition on, then off. Press valet button 5 times within 5 seconds, then once again (the alarm should confirm each step by chirping). Within 10 seconds press the lock (large) button on the remote and any other remotes you want to program.
