Thank you for the inquiry.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely. To reset the fuser count : The fuser count will be reset and then the printer is ready to use. Thank you for being a FixYa Valued Customer.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
This is caused by shoddy HP design - there is a small 15 tooth gear in the fuser, which breaks - as an end user you'd have to replace the fuser unit, as a tech you replace the gear (not available from HP, but available elsewhere for 80 cents)
SOURCE: Printer HP ColorLaserJet displays Fuser Error
Try to check resistant in Fuser unit See more HERE
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
LINK to part info
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
You have problem with the Low Voltage Power Supply
SOURCE: HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
SOURCE: I Have HP Laserjet 3055
You can reseat the fuser or you will have to replace the fuser. Please note the these machines the fuser is located in the middle of the machine. Most likley it's a bad fuser.
