I had the same problem. The electrolytic capacitors on the T761 are often faulty. Probably due to the high temperature of the unit. Replace C502 for the left front channel. Still better replace all capacitors of the front amplifier. I did this and it solved the problem.
Try to swap the input connector,
Hook up the right to left input and then the left to right input.
If the symptoms is still there then you have a faulty output IC on the left channel.
This is not DIY and I've advice you to send it to repair shop to isolate the problem.
Hope that you have only a dry joints on that area.
Thanks for using fixya.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check tyhe
