SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
SOURCE: technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
SOURCE: wanted. operating manual for an A55 mobile phone
Hello dunvegan2,
You can download the Manual of Seimens A55 by Clicking Here
Thanks for using FixYa.
