F-6 means for high current of compressor.Check to earth 50 MOhm minimum, if any reading. compressor is grounded. check run current, if it's high current, compressor defective.
Check compressor windings all equal 1 to 4 Ohms.If not replace compressor.
Please re confirm with all wiring (may be loose connection, short of wiring) before replacing compressor.
Helpful?
On that F6 I have also discovered that the indoor fan does not switch on, could this not be a reason? thanks Virgil
When the timer reaches the set time ie 15 min, the unit show f6 error and doesn't function unless I unplug it and restart
i found tha my indoor pc board is damaged and found that the 1.5uf cap for the indoor fan was the cause
i installed a universal pc board and had to wire in a new capasitor
