Question about Toshiba 65H82 65" Rear Projection Television
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has been on for a few minutes, or else after turning set off then back on. May recur 1-1.5 hours later. In that case turning set off then on clears problem - so far. Tech is coming out a second time to adjust picture. Was good for two weeks after first adjustment, then same problem. (Had a blown transformer and the three color filters replaced. Color separation first occurred a few days installation.)
  • Toshiba Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Re:  Toshiba 65 in - 7859b01.jpg
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluidRe: Toshiba 65 in - 65af323.jpg/>
6Re:  Toshiba 65 in - 69189a5.png class=
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jan 20, 2011
Anonymous
SOURCE:
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Bowed picture & red/blue/yellow separation
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 19, 2009 | Televison & Video
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 43H70 HD Projection TV
this is a convergence failure, there are hundreds of posts about it on this website you should be able to find everything you need
May 23, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
329 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
