Question about Dean Vendetta XM Electric Guitar
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
    Scholar:
    New Friend:
  • 80 Answers
Can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
Posted on Apr 19, 2014
2 Suggested Answers
6ya staff
SOURCE:
criss_michae
Cameron Lewis
  • 64 Answers
SOURCE: i have a dean vendetta xm and it wont make sound
If the wiring is correct on the guitar, try plugging it in to a different amp. If you still don't get any sound, the problem may be a faulty volume or tone potentiometer (or pot. The knob, for simpler words). These are fairly easy to replace if you know how to solder. If not, then watch this video: http://www.youtube.com/watch?v=BLfXXRfRIzY
You can get the pots from Musician's Friend, Guitar Center, or any music store that carries guitar parts.
If that doesn't fix it, then the problem is in your pickups. You can get "aftermarket" pickups through the above mentioned dealers, and you're not restricted to the original pickups.
What you replace them with will affect your tone, so do some research before settling on a set of pickups. Active pickups will give you more gain (great for nu-metal and hi-gain applications) and have lower output noise, but they require batteries. Passive pickups have no need for batteries, but tend to produce slightly more noise and hum.
Hopefully, it's the pots. That will be the cheaper fix, since they run about $2-$4USD each. Pickups can range from $100-$500USD a set.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Posted on Feb 11, 2011
One of the wires, (black), of my volume knob has come loose from somewhere; Where?
Yes, one will be an earth, one to the cord socket tip (that one is OK as does play), and one as you have said. It sounds like the wire to the tone pot has come off.
http://www.guitarelectronics.com/product/WD2HH3T11_00/Guitar-Wiring-Diagram-2-Humbuckers3-Way-Toggle-Switch1-Volume0Tone000.html
May 28, 2012 | Dean Vendetta XM Electric Guitar
I need a wiring diagram for a dean vendetta guitar
Go to either Fender, Gibson, or another guitar company, and look up wiring diagrams. Anything with 2 humbuckers and a switch is wired essentially the same.
Aug 28, 2011 | Dean Vendetta XM Electric Guitar
Hope that helps!
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I need a diagram for the wiring to the volume knobs and pickup selector
Try this link:http://www.guitarelectronics.com/c=eHnwOQQR5wgj1R3xxOCOwz9nB/category/wiring_resources_guitar_wiring_diagrams/
Nov 13, 2010 | Dean Vendetta XM Electric Guitar
Dean Vendetta XM Electric Guitar Logo
191 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
STEVE
Are you a Dean Music Expert? Answer questions, earn points and help others
