The crown has three positions:
Fully pushed in is the running position
Pull out to next position alows adjustment of the date
Pull out to third position allows adjustment of the time
Hope this helps.
Just register in the site and get the manual.
http://www.technomarine.com/Collections/List/Item/uf6-5.sls
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
you can pull out the crown stem to as if you are going to set the time and set the time to 12:00 (where the date will change over to the next day), then roll the time back to about 8:45 (just as long as you roll it back to before 9:00, this will work) and then forward it again to 12:00. The date should roll forward one day. Keep doing this until you reach your desired date and then set the correct time.
The second position just spins..doent change date.
