Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO CLEAN GREASE LOOKING SPOTS OFF THE SCREEN
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 20, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470278
Points
19564
Hi, LCD screen is quite different with crt screen. You should be careful while do cleaning. Unplug the power supply before do cleaning.
How to clean lcd screen: You can use isopropyl alcohol, hexane, petroleum benzine, glass cleaner with ammonia free.Apply the liquid to soft and clean cloth then wipe your screen. Repeat the steps until your lcd clean
Grease look on screen? Just use dampen cloth with water instead use above liquids as the may smear the contaminant across the screen.
Regards, Jay
Traeger has uneven heat on grill, some areas burn others under cook
The Traeger has hot spots like any other grill, especially in the front and back where the grease pan doesn't cover and over the heat box. You have to move food around or put your thicker pieces over the hot spots.
If it's getting really hot, you probably have grease in the bottom that's catching on fire. Be sure to clean it out regularly.
Oct 18, 2017 • Grilling
I need to remove my screen and clean my mirrors on my Mitsubishyi WD-82738 82" DLP. I cannot find a guide on how to do this for my particular model. Please help.
are you having spots on the screen? if so the problem is the dlp. they go bad looking like spots on the screen coming from the lens. its not the lens the dlp unit is failing.
I have a older washer. I want to clean it out (my whites are getting spots from the side of the washer) What should I put in the cycle to clean it out? Baking Soda? Vineger?
I am not too sure with what type of spots you are talking about. If it is rust spots you need to replace it because it cost more to replace the drum than to get a newer model. If you have grease spots it is worn beyond repair and I suggest to get a new machine. Good Luck
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 • LG WM0642H
GE Spacemaker appears to be sparking inside/top
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Cleaning top of gas range
Use DeBruce Polish I guarantee results go to debrucepolish.com
2answers
Alessi Tea Pot(not electric)
I do not understand why i must pay all I want to know is how to clean the greae from the Alessi non electric teapot so far I have tried 10 different produsts nothing works. thanks
1helpful
Greesey Spots.........
looks like the grease would be coming from the shaft at the middle of the tub. that would be the only source of grease in that area.you need to remove the whole drum to look at it.
7helpful
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
