SOURCE: printer stopped working after I cancelled a print job
SOURCE: My HP Deskjet F4580 won't print. Print jobs go
plaese folloW the instrutoion mention from the below URL and try
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00843712&cc=us&lc=en&dlc=en&product=3944758
still dose not work then try this url mention from the bellow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669384&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=3944758
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01361419&cc=us&lc=en&dlc=en&product=3944758
if still the issue is not resolve then contact hp tollfree number 1800-474-6836 they will replaced the printer if the warranty period is there.
hope this should resolve your problem
thanks
regards
HAMID
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
SOURCE: 1. HP7260 wont print magenta inks (light and
Possible fault with the main processor board or the print heads as your ink cartridges are new. so it will be good to have the head removed and cleaned once again, the mother board removed and reset.
Now un-install after removing printer from PC and reinstall and connect the printer.
If the test does not show magenta even when the ink display shows full capacity, the head or the processor can be faulty.
SOURCE: HP deskjet 5550 will not print. Flashing orange
Make sure the covers are closed completly. It will not print unless its closed. If its not that, then check to make sure you didn't knock one of the cables loose inside the printer, and make sure the belt that moves the cartridges is still intact and is not jammed.
