This link explains error 900 on a Lexmark printer. It includes troubleshooting steps in trying to resolve the issue.
http://www.marketpoint.com/article.cfm?id=100
If problem persists, contact the manufacturer.
I hope this works for you!
Thanks.
Monkey
"Understanding explains better..."
SOURCE: 900 service error with lexmark printer
LEXMARK 900 ERROR GENERALLY REFERS TO A BAD CONTROLLER BOARD.
SOURCE: Looking for a Lexmark Optra T640 Service manual ??
Try this link http://www.smartech-csi.com/portal/service/manuals/lexmark/lexmark-t640-t642-t644-4061-xx0-manual
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
SOURCE: 900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
SOURCE: error code 917.00 "service transfer roller" won't clear
This is a transfer roll error. Take the toner cartridge out and clean the area under it. The transfer roll is a roller which is right under the toner cartridge. make sure the ie is clean . It may need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
