SOURCE: wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
SOURCE: WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
SOURCE: This hardrive was in a
your drivers may have been corrupted or you might have a virus run your antivrus program Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on the plus signs (+) next to the following folders
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Testimonial: " I have never done anything this advanced, will be a real leraning experience. I will print out and go step by step, Thanks for advice."
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
http://download.cnet.com/western-digital-disk-manager/3000-2122_4-10008018.html
This file contains the most up-to-date Disk Manager drivers for Windows 95 and Windows NT 3.5.1. This file fixes numerous issues, especially those with IBM PS/1 Value Point machines. These drivers will replace Ddloader.bin and Xbios.ovl files that were installed with previous versions of Disk Manager.
hope this helps you
