Hello Jamie, I understand how annoying it is to connect an older game console, such as the Atari 2600, to newer TV's. Do not fret, all you need is an adaptor to connect between the Atari's RF cable, and the coax jack on your TV. For example (image curtesy of google search): http://ecx.images-amazon.com/images/I/41pLoQfSzcL._SL500_AA300_.jpg
Ghosting or blurring vision happens due to a faulty video processing board. It may be due to faulty T-con board (BN81-01308A) or a main board ( BN94-01199B ). However, you'll need to check the wiring on both of these boards. Before this I'll suggest you to callibrate the TV by following these settings--
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320. Knowledge obtain from: Repair experience on same symptom. Parts reference: Andrews electronics, 800 289 0300.
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Turn off the system, Then when its in standby mode when the red light is on, press and hold the button to turn it on, Wait untill you hear 3 beeps then let go if the system turns off try it again its a master reset then just restore factory settings
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
